dimcic
(Milos Dimcic)
October 22, 2021, 11:31am
1
I have a short about automatically importing STP files (and saving them as Rhino files).
First “pre-question” is, when creating a new RhinoDoc, I need these template names, is there a list of those strings somewhere?
RhinoDoc newDoc = RhinoDoc.Create(“Large Objects - Meters”);
And the question is, once I use:
if (newDoc.Import(file))
I get this STP import options prompt in Rhino:
Is there a way to supress that? Because If I import 100 files I have to click Enter 100 times.
P.S. An advice if I should do it with RhinoDoc.Create or maybe CreateHeadless or maybe with File3dm is also welcome. Imagine a simple automated conversion tool, that goes through STP files, imports one by one and saves each one of them as 3DM.
Thanks.
dale
(Dale Fugier)
October 25, 2021, 6:35pm
2
Check Tools > Options > Files > Template Files.
How about something like this?
import Eto
import Rhino
import System
import scriptcontext as sc
def __browse_for_folder():
dlg = Eto.Forms.SelectFolderDialog()
dlg.Directory = Rhino.ApplicationSettings.FileSettings.WorkingFolder
if dlg.ShowDialog(None) == Eto.Forms.DialogResult.Ok:
return dlg.Directory
return None
def test_convert_step():
folder = __browse_for_folder()
if folder:
files = System.IO.Directory.GetFiles(folder, '*.stp')
for in_file in files:
sc.doc.Modified = False
script = '_-Open \"{0}\" _Enter'.format(in_file)
Rhino.RhinoApp.RunScript(script, False)
out_file = System.IO.Path.ChangeExtension(in_file, ".3dm")
script = '_-Save \"{0}\"'.format(out_file)
script = '_-New _None'
if __name__ == "__main__":
test_convert_step()
– Dale
