Had two calls this week from clients saying that they are not able to import SW 2019 files. I told them this is “normal” as Rhino is always a version or two behind. They were not all that happy about that…
Is there a way to save out a previous version of files from SW? I know that Autodesk products usually can, but the client did not know how to do this in SW (and I don’t know SW at all).
Any plans to update the importer with a service release? Maybe for the WIP?
At the worst case I can have them export STEP from SW, but that is not the ideal solution.
It seems it is not possible.
A model from an earlier version of SOLIDWORKS is automatically converted to the newer version of SOLIDWORKS when you save it. You cannot do a save as to an earlier version, and you cannot open the newer version with an older version of SOLIDWORKS, with one exception. You can open part and assembly files in read-only mode in Service Pack 5 of the previous release. http://help.solidworks.com/2019/english/SolidWorks/sldworks/AFX_HIDD_FILESAVE.htm
If I remember correctly from the time when I was still using Solidworks (in school, before I truly discovered Rhino, that is), there is indeed no way to save as a previous version of solidworks. This makes it impossible to collaborate with other people that don’t run the same version as you have and forces you to buy the latest version. Pretty insane.
Hi Mitch - the WIP might support 2019 already - not sure.I expect it will if it does not of course, but I would not expect V6 to at this point. I’m not even sure I have any 2019 files around to test.
