Hi @Xavier_Ayme,
Thanks for this - I’ve reported it as a bug.
https://mcneel.myjetbrains.com/youtrack/issue/RH-41234
– Dale
Hi @Xavier_Ayme,
– Dale
question on this method vs programatically… I have a scenario where i need to import , BUT, default import methodology is to show all hidden layers from the import file and I need it NOT to do that…
(ie: if i save a file with some layers turned off, when i use rhino script as above it completes import AND shows all the previously hidden layers.
Any way to turn off that function in the command line version or i have to go low level fileio and manually add layer by layer.
Your best bet is let Rhino import and then have a post-import process that sets the model to what you want.
– Dale
