i try to import floor plans into rhino 6 the layers showed up but no lines.
i export the drawing from arris 9.4 to dwg.
Any suggestions
New Be to your world.
Gregory
Any suggestions
Gregory
Hi Gregory - can you send us an example file?
So attached is my dwg file exported out of arris 9.4 with a translator 7.7 Expert InfoCAD DWG/DXF Translator.
I tried to import it once I open Rhino v6,
Gregory Minaker, Architect
Minaker Architecture,ps
360-435-1113
Offices;
Oso; Oso School House, Monday & Friday (by appointment only)
Mailing Address; P.O. Box 464, Arlington,Washington,98223
flrpl01.dwg (345 KB)
Hi Gregory - that seems to work fine in Rhino 6 here with the file that you provided.
Just to make sure - how are you determining that no lines are getting in?
Could you please run the Rhino SystemInfo
command and post the result here?
I imported your dwg into V6 here, it comes in with a bunch of stuff. Four layers are locked.
If I do a SelAll I get:
1 block instance, 86 curves, 1 mesh, 51 texts added to selection.
If I unlock the 4 layers and do a SelAll, I get:
15 block instances, 2150 curves, 1 mesh, 51 texts added to selection.
What’s missing?
Here is a screenshot.
This what my screen looks like, 15 block instances 2088 curves
360-435-1113
Offices;
o’k i found it, sorry i zoom out way out and it was sitting up in the corner of the db, thanks.
is there a good reference on how to set the menu before importing.
Thanks For helping. Gregory
