Importing Accord package to c# in visual studio when customizing grasshopper component
I am using c# to develop plugins for grasshopper.
I have successfully built some plugins.
However, when the matrix operations (inverse, etc.) were needed, I imported Accord package to deal with this problem.
I have tried runing the code in visual studio, and the code ran as expectation.
When I import the gha file and access the component in grasshopper, an error messgae came out, saying: "1. Solution exception: failed to load the file or assembly “Accord.Math, Version=3.8.0.0, Culture=neutral, PublicKeyToken=fa1a88e29555ccf7” or one of its dependencies. The system could not find the specified file. "
And I have tried importing Accord.dll into c# component in GH, but unsure about which version of Accord.dll I should import, hence failed to make it.
The codes that I have tried in visual studio is:
// use Accord.Math
protected override void SolveInstance(IGH_DataAccess DA)
            int numRow = 5;
            int numCol = 5;
            double[,] A = Accord.Math.Matrix.Random(numRow, numCol, 10.0, 100.0);
            DA.SetDataList(0, A);
// use Accord.Math
Any hints would be greatly appreciated.
Big Thanks!
Hi @Robin_HE,
Did you copy the Accord.Math assembly into the the same folder as your Grasshopper .GHA?
– Dale
Hi Dale,
Thank you for your kind reply!
I have copied the Accord.Math.dll to the same folder.
However, it still doesn’t work.
Thank you again! @dale
Robin
Hi @Robin_HE,
Is the source to you Grasshopper project available somewhere?
Also, RhinoCommon does have a Matrix class…
– Dale
Hi Dale,
Thank you for your reply, I really appreciate it, hopefully we can work it out.
I have uploaded my project on Github, the link is:
And thank you again for telling me the Matrix class in RhinoCommon, but I might need to do some matrix inverse operation later, and I wish I could customize the component so as to speed up the solving procedure.
Big thanks! @dale
Robin
