I imported an OBJ file into a Rhino scene. It said it imported but haven’t been able to locate it. V-Ray throws an error when I render the scene, saying xxx OBJ couldn’t load an mtl file that is in the same folder. I have no idea how to find the OBJ object and delete it.
Hi @rstepp, usually imported object(s) are selected after import so you could try _Zoom _Selected
right after the import. If it zooms to something visible, you might inspect that mesh object.
In case you had no other meshes in your file before the obj import, use _SelMesh
followed by _Zoom _Selected
_
c.
