I import a lot of step files, and each time I end up with having to explode all blocks, then I still can’t delete layers that have block info (even after I’ve moved all of the geometry to a new layer) so I have to go to the block manager, identify which blocks are nested in which ways so that I can delete them in the order that I’m allowed to delete them in, then delete the other blocks. Is there a way to streamline this process? I simply want the geometry, not any block information.
