hi guys, i was wondering if there is a workaround being able to import non - coplanar rhino polylines as native ceiling surfaces/elements in revit? i have a script that works great for co planar polylines, but my ceiling has angled surfaces and my node allows only co planar geometry.
Sloped Ceiling are controlled in Revit via its sketch, this feature isn’t available via the Rhino.Inside.Revit component.
Alternatively you can create a Direct Shape on the Ceiling category, but do note this is not a Native Revit Element and has limited Materials and Editability in Revit.
i understand, what about roof elements? there is a posibility to draw in revit roof elements by face, which are sloped. Would that follow the same restrictions? so the workflow would be - rhino sloped curves imported in revit as native roof elements
There are restrictions and work arounds, take a look at some of the previous posts.
https://discourse.mcneel.com/search?q=%23rhino-inside%3Arevit%20roofs
