Import Skp file with C# script;
The confusion I encountered is that I can’t import skp files because of this option set. How can I skip it or “enter” it?
Thank you very much!
Have a nice day!
I see this - thanks for reporting.
https://mcneel.myjetbrains.com/youtrack/issue/RH-66490
You can work around this by doing the following:
  private void RunScript(string skp, bool enable, ref object A)
    if (enable && !string.IsNullOrEmpty(skp) && System.IO.File.Exists(skp))
      var script = string.Format("_-Import \"{0}\" _Enter", skp);
      RhinoApp.RunScript(RhinoDocument.RuntimeSerialNumber, script, false);
– Dale
Thank you, Dale! I will try this.
RH-66490 is fixed in Rhino 7 Service Release 14
