when i read a rhino file with
a = Rhino.FileIO.File3dm.Read(x).Objects
how can i filter these objects by group or better how can i import a group of geometry objects to rhino by group name.
second option is prefered.
Thanks in advanced
Thanks in advanced
Hi @flokart
If you are using Rhino 6 then this sample will get you started:
import Rhino
import scriptcontext as sc
__author__ = "Lando Schumpich"
__version__ = "1.0"
__email__ = "lando.schumpich@gmail.com"
def getGroupsFromFile3dm():
# your filepath here
sFilePath = "D:\\RhinoForum\\GroupsFromFile3dm\\groupsFromFile3dm.3dm"
# your desired groupname
sTargetGroupName = "Group01"
# read file3dm
file = Rhino.FileIO.File3dm.Read(sFilePath)
# find group for target name
group = file.AllGroups.FindName(sTargetGroupName)
if not group: return
# when you open a rhiodoc you could just run groupTable.GroupMembers(iGroupIndex)
# we have to do it the hard way because there is no helper for file3dm
# start by iterating over all objects
arrGroupObjects = []
for obj in file.Objects:
# test if object is in our found group
if group.Index in obj.Attributes.GetGroupList():
arrGroupObjects.append(obj)
# add all found objects to the rhinodoc
if arrGroupObjects:
for obj in arrGroupObjects:
sc.doc.Objects.Add(obj.Geometry)
# redraw views so we can see what we have done
sc.doc.Views.Redraw()
if __name__ == "__main__":
Thanks a lot for your help Lando Schumpich,
unfortunatly
dont work and i have no idea why, it returns all time None no matter wether groups exist or not , only FindIndex work so i have to iterate over the group table to find the right group.
GrList = []
for i in GrTable:
if 'TEST00' == i.Name:
GrList.append(i)
Another thing is that if i bake the object geometry the group attribute get lost and i have to add the object again to the group.
But anyway it works to import group objects and bake it to layers as grouped objects, again thanks a lot for your clean code example.
