Import PDF's into Grasshopper
I’m hoping to directly import a set of PDF’s into Grasshopper. I’ve been searching the forums and found this discussion ( Insert PDF as block in Rhino - Grasshopper (grasshopper3d.com)), but these definitions import the PDF’s as blocks into Rhino. Two questions:
  1. Is it possible to directly import PDF’s into Grasshopper? If not, why?
  2. Has anyone been successful doing so?
Thanks in advance!
Hi Brian -
The Import 3DM parameter also imports PDF files:
Fantastic! Thanks Wim!
Hey @wim …is there a way to get the layerinformation of the objects to sort them properly?
