I’m converting my program to run in Rhinocommon for V6, I have a reference to Arrayint which is from Opennurbs, but I can’t find how to import it, do I need another reference file?
Thanks,
Don
Thanks,
Don
Found it, Never mind.
Alright, I cannot get past this Arrayint thing, someone helped me with this years ago, so hopefully this will be an easy transition. I would like this to run in RhinoCommon for V6. I have been chasing this for hours now. Any help?
Public Function DisplayModesList() As RMA.Rhino.IRhinoCommand.result
'Use the display attributes manager to build a list of display modes.
'Note, these are copies of the originals...
Dim attrs_list As New MDisplayAttrsMgrList()
Dim attrs_count As Integer = MRhinoDisplayAttrsMgr.GetDisplayAttrsList(attrs_list)
If (attrs_count = 0) Then Return IRhinoCommand.result.failure
' Construct an options picker so the user can pick which display mode they want modified
Dim go As New MRhinoGetOption
'go.SetCommandPrompt("Display mode to modify mesh thickness")
Dim opt_list As New Arrayint(attrs_count)
opt_list.SetCount(attrs_count)
For i As Integer = 0 To attrs_count - 1
' Verify the display mode had a valid CDisplayPipelineAttributes pointer
If (attrs_list(i).m_pAttrs Is Nothing) Then
opt_list(i) = 0
Continue For
End If
' Get the display attributes English name
Dim english_name As String = attrs_list(i).m_pAttrs.EnglishName()
english_name = english_name.Replace("_", "")
english_name = english_name.Replace(" ", "")
english_name = english_name.Replace("-", "")
english_name = english_name.Replace(",", "")
english_name = english_name.Replace(".", "")
'Add name to combobox
DisplayModeComboBox.Items.Add(english_name.ToString())
Next
Return IRhinoCommand.result.success
End Function
Dale,
I should be able to decipher what I need from this. I wish I would have just jumped to C#, most of your samples are C#, if I had only known!
Thanks,
Don
Got it!
Thanks Again!
Don
