I have one problem.
I have done to save the sence of rhino5 to *.obj file with python code.
import Rhino
def Export():
# select all objects to export
objs = rs.AllObjects(select=True, include_lights=False, include_grips=False)
if not objs: return
# setup path and filename in quotes
file = chr(34) + "D:\\testFile\\test"+".obj" + chr(34)
# create export command
cmd = "_-export " + file + " " + " _Enter _SelNone "
# run the command
rc = rs.Command(cmd, False)
if not rc:
print "Error exporting file {}"
if __name__=="__main__":
Export()
But I don not know how could I import *.obj file in 3dsMax with python code. It dont by -File -import file.
Does have cmd command in python do this?
Thank you for your help.
Best,
Alen
