So I have a very large file with many large objects on it. I want to export a small object (singular) from this file into another. I have already matched to scale the object to be suitable for the file I want to put it in.
I selected the object>file>export selected > exported as a 3dm. The I opened the file I wanted to import the object into.
I went import> and selected the file.
But the entire large file was then imported instead of the one object, it is now very slow. How do I fix this/ do it correctly
Sounds right…maybe you SavedAs instead of export? Maybe the objects were actually grouped together and exporting one object dragged everything else with it?
If the objects are grouped, subselect the objects (CTRL+Shift+LMB) and export them (Rhino will export only selected objects even if they are part of a group).
Imho, a simpler way would be to open both files (two Rhino sessions) and make a copy / paste from one session to the other.
i.e.
In the first file select the objects (or sub-select if they are into a group) and press CTRL-C
In the second file press CTRL-V and the objects will be pasted.
Sorry, I don’t understand… can you explain better what happens after pasting the object?
Is the object moving in a different place after pasting or something else appears when you move the pasted object?
simple trick to see if the selection is a problem:
copy paste to a new empty “intermediate” rhino document
do deleting, scaling, moving, layer-Assignment in the new document.
now copy paste from the “intermediate” doc to the target.
