Import lock layer unexpected behavior?
If I import a file which has a locked layer, when the file is imported all objects will be selected, which means I can modify the objects on the locked layer. Doesn’t it seem that only the normal objects should come in as non-selected?
Sam
Hi Sam - got that, thanks.
( This appears to be working correctly in the V6 builds here.)
