Hi! Is it possible to allow multiple selection in “import layout” dialogue? Maybe there are other dialogues that would deserve the same functionality Going nuts when working from 100 layouts
Petr
Petr
I just looked in ImportLayouts ui the V7 WIP and a selection dialog opens with all of the layouts in the other file selected with check boxes.
What is it you need different that that?
Well, multiple selection should work in both directions. If I want only 2 layouts to be imported out of 100, I must click and deselect one by one. I also had this problem when turning off the layers in details. In general layer panel you can use multiple selection (shift), but this functionality does not work in the panel controlling layout/detail layers.
cool
