Import from OpenSCAD
nurb_and_mesh.3dm (2.4 MB)
is this possible? I like the parametric abilities in OpenSCAD, but would love to get the model into rhino once its finished with general proportioning.
in the attached file you’ll find a model built in rhino, another built in opens cad.
Even if I was able to extract curves from imported OpenSCAD files that would be useful.
Thanks,
rev
Apparently, OpenSCAD will export as a DXF. I would do that then import into Rhino.
I have found DXF is generally the most reliable format to use to exchange data.
