After the recent rhino update 7.26
when i import a dwg to Rhino 7 there seems to be some missing curves, this didn’t seem to be the case before i updated was wondering if anyone else was having the same problem ?
I’m still on Rhino 7.25 and also in this version not everything that is seen on the right in your picture is getting imported. Which version were you running prior to updating to 7.26?
I opened your file in AutoCAD 2018 as a check and the missing curves are there, but AutoCAD complains that the DWG file was created with a non-Autodesk application.
Where did the DWG come from?
