Import File Type Behaviour
Some of my projects (interior scenes especially) have me downloading a variety of 3D models from GrabCAD, McMaster Carr, CGTrader, etc.
  1. When I first run the Import command and click on my Downloads folder I see all the files I downloaded because the File Type box in the bottom right initially defaults to Supported Files.
  2. I import the first model which is a STEP file.
  3. I then run the Import command again, but now the File Type box in the bottom right has changed to STEP instead of Supported Files. So I have to go over and click the drop down list to change it back to Supported Files so that I can see and import the next file which might be a SLDPRT.
  4. I then run the Import command again, but now the File Type box in the bottom right has changed to SLDPRT. So I have to go over and click the drop down list again to change it back to Supported Files so that I can see and import the next file which might be an OBJ.
Is there a way to change this behavior? Having it always show all supported file types would be ideal.
Instead of importing file after file, you could also just drag and drop all the files out of the explorer onto a viewport in one go.
I mean sure, you could do this. If you had a group of files with different formats to import all at once then batch importing via dragging into viewport would definitely save time, but the issue I pointed out with the Import command still remains. It’s default behavior should be a selectable option.
