Import file from Rhino (dxf) to Treble
I wanted to import my Rhino file (dxf) to Treble, however, it said “The file only contains unsupported geometry type ‘3DSOLID’. Set DXF export settings to Mesh / PolyFace” when i exported the file with 2004 Solids and said “The file only contains unsupported geometry type ‘POLYLINE’. Set DXF export settings to Mesh / PolyFace” when I exported the file as 2007 polylines. So I tried to mesh everything but it looks a bit weird…
Screenshot 2024-06-01 at 12.33.08 AM
I tried to upload it on Treble right now but it’s taking forever
I’m pretty new here, a littel help here and there will be much appreciared, thank you!
What happens if you mesh the object first in Rhino and then export the mesh as .dxf?
