I have this problem. When I import a 2D layout created with Autocad, all dimensions with tolerance are reset to the tolerance value of dim style even if some dimensions have the tolerance value changed or killed from the dim style . I import the same file in SolidWorks and the dimensions are perfect as in Autocad.
