Import dwg. text garbled in RH7 but correct in RH6
As describe in tile and the images below, any ideas?
RH7
RH6
TEST FILE
TEST FILE.dwg (157.2 KB)
Hi -
Please post a DWG file that behaves like that.
Hi Wim, here’s the test file.
Hi Justin -
Thanks for that file.
When I import it into Rhino 7 on my end, this is what I get:
Could you please run the Rhino SystemInfo command and copy-paste the result here?
Hi Wim, my Rhino7 SystemInfo shown as below:
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09001, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Commercial, build 2021-10-20
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 SUPER (NVidia) Memory: 8GB, Driver date: 5-15-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 446.14
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-15-2020
Driver Version: 26.21.14.4614
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21293.9001
Hey Wim,
Just an update, from my end we have found that not only mine but others of the same RH7 commercial license have the same issue.
Hi Justin - what happens if you reduce the ‘model space scale’ for that dimension style in DocumentProperties > Annotation.
Hi Justin -
Thanks.
I can confirm that these annotations get garbled in Rhino 7.11.
I’ve now also tested with the current 7.12 version and that works fine. Please update to the current Service Release.
Thanks Wim, after update the import text looks correct now!
