I have a two plug-ins that both read files with extension “.dat”.
When I open (Ctrl+O) a DAT file and select the correct file type, the correct plug-in gets used. When I import (Ctrl+I) the file and select the correct file type, the incorrect plug-in gets used. I guess that the first plug-in that the system finds that can read .dat files gets used on Import but not on Open?
The fact that Import ignores the selected filetype is, I guess, a bug.
If you are going to do something about this, please consider the following: if multiple plug-ins are capable of reading a certain extension, could you please ask the user which of the matching file types they want to read:
______________________________________________________[ X ]
Rhino has found multiple plug-ins that can read .dat files,
please select the filetype you want to read
[X] Filetype 1
[O] FileType 2
[O] FileType 3
[√] Remember my choice
[Cancel] [OK]
___________________________________________________________
I’m obviously just misunderstanding… sorry. I see it from another angle now. I thought these were plugins you wrote! I switched the topic back but Dale might still be able to help and should get a ping now that I mentioned him.
Just to be 100% clear, I did write the plugins. But they are not at fault, it is the way Rhino handles the situation where more than one plugin can handle the same file extension.
Any news on this? There is another super-irritating case, that gets me every time.
I import a file with .DAT extension and select BY HAND the second .DAT file type that must be loaded. The next time I import, the selected file type is the first file .DAT file type is pre-selected in the load file dialog. THIS IS WRONG, I SELECTED THE SECOND ONE!
PLEASE CAN YOU MAKE RHINO REMEMBER THE LAST SELECTED FILE TYPE NOT THE LAST SELECTED EXTENSION?
It seems like a super simple thing to fix, but 9 months and several Service Releases later: nothing has changed.
