Hi, apologies if this has been answered previously.
We are currently working with Microstation DGN files. They open just fine and work well, but none of the references in the DGN file are imported, and as far as I can tell, there isn’t an option to do so.
It would be useful if there was an option to import references the same way you can insert blocks, and for a dialog to come up when opening the file.
Any advice other than manually importing them all?
Can you please send us a small, simple DGN file with a couple of these “reference files”?
We need an example that opens correctly in Microstation but not in Rhino.
Then we can see if the DGN file reading library we use supports these reference files. If it does, we may be able to improve the reader.
Hm yeah it did get kind of side tracked, sorry about that, my fault I’ll split this to a new topic, … I do not know if that is possible, reading in references - but there is a bug track item for it now.
@Ben_B the developer is looking now, into what might be needed to do this - it may or may not be something we can do in the near future.
