Sheet018v4.txt (4.4 MB)
I am trying to use the import coordinates component to read XYZ data from the attached .txt file. Unfortunately it does not work.
I have set the file location, separator is a single space. Is the issues due to the repeated spaces? I tested this with a few coordinates deliminated by a “,” and this did not fix the issue. Any advice is much appreciated.
Thanks Japhy. I will see how my laptop handles the domain = 0 to listlength - in Excel I am accustomed to specifying repeated deliminators can be ignored - is this a feature that could be implemented in the XYZ import component?
