Import Content crashes on SR24 when importing any DWG file
It seems Rhino SR24 crashes when using Import Content component in Grasshopper, picking any DWG file and pressing/initiating the import.
Hi Tuomas,
Can you run SystemInfo and post the result.
I can’t repeat in 8.25.25287.15431. Does this happen if you start Rhino 8 in Safe Mode as well? (sans 3rd party plugins)
Here is the SystemInfo:
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092)
License type: Commercial, build 2025-10-08
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 5-24-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.94
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA RTX 3500 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 5-24-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.94
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 7-8-2024 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2024
Driver Version: 32.0.15.5594
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SW_UpdateManager\2.0.0\SW_RhinoPackageUpdate.rhp “SW_UpdateManager” 1.0.3.0
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\25.10.9.8\bullant.rhp “bullant” 25.10.9.8
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggRhinoETABS\25.10.1.8\net48\ggRhinoETABS.rhp “ggRhinoETABS” 25.10.1.8
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggRhinoIFC\25.10.13.8\ggRhinoIFC.rhp “ggRhinoIFC” 25.10.13.8
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.50925\net48\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.24.25281.15001
C:\Users\tuomas.lehtonen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25281.15001
Yes, it happens with Safe Mode too. I pretty much enabled all the plugins in Safe Mode whenever it asked for it. But also if I only enable the native plugins, it crashes.
I rolled back to 8.24 and seeing the same thing. Going to test the latest again before making any recommendations.
Sending you a link to rhino_en-us_8.25.25293.17001 en, which is working as expected in this regard.
Same issue, dwg import in large usage. Could please provide link to SR20 or to rhino_en-us_8.25.25293.17001 en?
Yeap same issue. Any idea when fix is coming?
@jhs , @Armandillo
Based on what Japhy wrote, the current public Service Release Candidate should work for you:
Thanks for the info @wim ! It is available from Rhino 8 app as release candidate. I prefer to use official releases :slight_smile: So back to SR20 if installation package is available :slight_smile:
This official release is recommended.
I updated from SR20 to SR24 –> reason why I was asking SR20 installation link…:see_no_evil_monkey:
We hope the next Service Release will be published soon, as we are unable to use the candidate versions.
