Hi @mathieu1 ,
I don’t know why but the Import Bitmap doesn’t function!
I’ve attached a file containing the ImportBitmap and gITFDisplay. I’m using Rhino7
Thank you!
Import FootPrint.gh (4.5 KB)
Hi @mathieu1 ,
Thank you!
The glTF 2.0 Display component does not work with bitmap images, only with geometry. You need to create an object (for example, a Mesh Plane) and assign the image as a texture in the object’s material:
Import FootPrint_FIXED.gh (12.5 KB)
Thanks!
