hi
i am importing files using this vbascript
Sub Import_All_Text_Files()
Application.ScreenUpdating = False
Dim thisRow As Long
Dim fileNum As Integer
Dim strInput As String
Const strPath As String = "C:\Temp\Temp\" 'Change as required
Dim strFilename As String
strFilename = Dir(strPath & "*.txt")
With ActiveSheet
thisRow = .Range("A" & .Rows.Count).End(xlUp).Row
Do While strFilename <> ""
fileNum = FreeFile()
Open strPath & strFilename For Binary As #fileNum
strInput = Space$(LOF(fileNum))
Get #fileNum, , strInput
Close #fileNum
thisRow = thisRow + 1
.Cells(thisRow, 1).Value = strInput
strFilename = Dir
Loop
End With
Application.ScreenUpdating = True
End Sub
but the problem is i can’t able to import other language text files. so please add utf-8 code to this script so i can import all text files in any language.
