Dear Rhino Developers,
can you please enable full layer filtering on the layer input of the Import 3dm component?
Thanks
Thanks
Hello - what I think you mean is that you’d like to import some but not all layers from another 3dm file, correct?
Hi Pascal,
I often have files with identically named sub-layers. As of now, I have to use the name filter to reference let’s say version 02 of an object. That means if I have multiple sub-layers with the same name, multiple objects will be referenced in one branch.
Correct me if I’m wrong. The layer filter of the Import 3dm component does only look at a flattened layer structure.
I think it should look at full layers… layer::sub-layer::…
Hello - I guess this is a Grasshopper question, is that correct?
Yes that’s correct!
