Since the last update in Rhino 8, when I try to import a .dxf file using import 3DM, it just crashes. Anybody else with this problem?
Hi Raffael -
Is issue is fixed in the public release candidate for Rhino 8.25.
You can change your update frequency to automatically get to download a current version.
Rhino 8 and WIP has a better importer in Grasshopper. It brings in the geometry and all the properties of the model. It will import any format Rhino imports:
This also then can be run thru filters: Rhino - Grouping and Filtering Data
