I have an FBX saved in Centimeters and since Import 3DM supports all formats,
when I use the importer within GH it always appears this dialogue in the command: Rhino units are Millimeters and scale it by 10.
Why does the importer doesn’t use the current unit and always assume millimeters? Is this a bug?
Even if I use Centimeters as you can see, thank you!
Command: _Grasshopper
FBX units are Centimeters
FBX geometry will be scaled by 10.
