Hi guys. I am immigrating an opennurbs 5 application to 6. However, I found that the ONX_Model_Object class is entirely gone. Could I ask is there an replacement for this class in opennurbs 6? Thanks very much!
I may solve this problem. I used the component iterator to get components from model now.
I am using modelObject->Attributes(&ON_3dmObjectAttributes::DefaultAttributes) to get attributes like visibility, mode etc. However, I am not confident with this way. Is there more straightforward way to access attributes like visibility or layers of an object? Thanks for any reply in advance!
The replacement ONX_Model_Object, found in earlier version of openNURBS is ON_ModelComponent. And yes, using a ONX_ModelComponentIterator iterator is the correct way for getting components.
If you need a model geometry component’s attributes, use ON_ModelGeometryComponent::Attributes.
Could I ask one more question? I am trying to access geometryList in instanceDefinition by using InstanceGeometryIdList from InstanceDefinition. However, it always return me a zero length list no matter what model i am using. Is there any better way to traverse the scene tree via instanceDefinition?
Attached is an example of traversing all of the instance definitions in a 3dm file. Note, this sample is in Rhino SDK command form, but you’ll get the idea.
thanks very much Dale. I think I am doing the right thing, my code is generally the same idea of yours. The only problem is the InstanceGeometryIdList always contains no ids. I will give it another try.
