Hi community. Sorry for the basic question but i would like to wrap/stretch an image around a four sides of a cube. Could anyone help me? Right now the same image is repeated on all the sides.
Hi John,
Select the box and in the Properties panel > Texture Mapping section… use Unwrap and then select one vertical edge of the box as a seam. Then make sure the texture in the assigned material is set to mapping channel 1 and adjust the placement in the UVeditor also in Properties > Texture mapping for the box.
Thanks so much Brian. Great to hear from you.
