Using Adobe AI CC - Do you have any suggestion on this to import AI-paths in Rhino? Will help me a lot! H
I presume you mean that you want to get the fill information in with the path outline?
Saving as Illustrator won’t help, however exporting from Illy as DWG will give you the path/s as objects and the fills as solid hatches
On the other hand you CAN export filled objects to Illustrator from Rhino by hatching solid, then exporting as .AI
HTH, Steve
Steve! Big thanks for clarifying!
