IGH_Param.ReplaceSource Bug?
I’ve realized that if you try that:
myParam.ReplaceSource(sameSource,sameSource);
The source is actually removed instead “replaced”, so probably it should do nothing, obviously it can be avoid be comparing the old and the new source before adding, just for your information @DavidRutten probably it’s easy to fix.
Kind Regards.
Thanks, logged under RH-51591.
