IfcSite / ifcProject - How to set values in VisualARQ
I am wondering if it is possible to set up value for ifcProject and ifcSIte in IFC export using VisualARQ?
Hi @Natalia_Gawlik
You can use User texts to define the ifcProject, the ifcSite, and other related names when exporting your document to IFC.
    1. Run the SetDocumentUserText command
  • 2 . Type one of the following text key:
    • IfcProject_Name
    • IfcProject_Description
    • IfcProject_LongName
    • IfcProject_Phase
    • IfcSite_Name
    • IfcSite_Description
    • IfcSite_LongName
    1. Type a document text (the text given to the chosen key)
Hi, I cant seem to find the IfcSite export at all. Changing the Ifc Entity in the Export Options does not show an IfcSite option
I need this for my Course to export as IfcSite
Hi @moritz.powik, you won’t find the ifcSite within the list of ifc types because that list is only for physical products.
VisualARQ exports automatically the objects according to the building and level where they are located. All objects in the model located below the elevation of the lowest level are exported to the ifcSite.
