IFC issues
Lately I’ve had to prepare some IFC models, so here are my insights about the process.
The model is quite simple, the only problem is connected to its nature: it is a renovation and expansion of an existing building. I could later add some my remarks about this. So, I use lots of external blocks as parts for various VA entities (doors, windows, others), and when modelling with VA it works fine. No, not fine - it works perfectly :wink: I don’t need the model to be a perfect “Revit” standard, it is just for collaboration with other contractors. Some of them use Revit, some use ArchiCAD, thus an IFC format should be enough. I use their IFC models as inputs for checking collisions and other solutions.
So, first of all I export model using these settings:
Nothing special, except I set off layers with unwanted entities. I use quite a lot of surfaces / curves to model irregular shapes, mostly irregular walls. I don’t want to get a messy IFC model, with lots of proxies, so I just exclude these elements from exporting. Here is a picture with a list of external blocks:
Then, when opening the IFC file with Rhino I get a list of invalid boolean intersection:
Frankly, I cannot say where are these errors, as the model seems to be quite good - except 3 windows:
It is the same style for these incorrect windows. Maybe its definition needs to be improved? I will check it.
When opening the same IFC file with BIM VISION (a free IFC viewer) everything seems to bo good:
A further investigation shows some errors, but (for now) these are not painful (for me, of course). For example, there is invalid assignement of some entities to building floors:
On the other hand, the model keeps original layer structure:
And finally, the IFC keeps user parameters :slight_smile: Here is the model with users’ parameters - as a _Pset category:
And the IFC file keeps these parameters as they should be:
So, I would like to thank you, all Asuni guys, for your hard and good work :slight_smile:
Cheers, Jaro
p.s. my structural engineers says he has never get such a good model made with Revit :wink:
Hi Jaro, thank you for your encouraging and kind words. There is still a lot to improve for IFC import and export features. So we will be eager to help you with any issues you may encounter.
For example these ones:
If you can share the file you are exporting to IFC, we will investigate where this boolean issues come from, and why the windows are not imported properly.
Cheers!
