I’ve got an issue when I try to export an IFC with a 0,0 point far from the général plan origin.
When model is imported in Revit, VisualArc levels seems to stay attached on the général plan origin and it produce a visualisation bug (model is too big cause of the to big distance between model and level origin point).
I need to do this because BIM manager ask me to export a georeferenced model…
Model origin (0, 0, 0), will be located at the position specified in this dialog (latitude, longitude), and these values are exported and imported from the IfcSite in the IFC file.
