If you constantly use the "TestZBiasFactor"
2023-12-07_Disc.3dm (932.7 KB)
This is a simple disc diameter = 1000, center at 0,0.
In Monochrome and Artistic the view is not good:
TestZBiasFactor = 8 is better.
Same for this model (Sweep2 from tutorial files):
Is better with TestZBiasFactor = 64.
And in V7 it is acceptable without fiddling with TestZBiasFactor:
If you constantly use the "TestZBiasFactor" command to fix display artifacts, please send a sample model to
McNeel technical support so we can fix Rhino and get rid of this test obscure command.
Done.
OOBE for V8 could be better…
