According to the documentation Extrusions have an IsCylinder method, but in my code it is says an ExtrusionObject has no such attribute…? I guess I need to break it down first? Or do I need to cast the extrusion differently?
Hi Jim,
What documentation did you read that in, I cannot find it here:
https://developer.rhino3d.com/api/RhinoCommon/html/Properties_T_Rhino_Geometry_Extrusion.htm
For surfaces there is an IsCylinder method:
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_Geometry_Surface_IsCylinder.htm
-Willem
Hi @JimCarruthers,
You have two different things here.
Extrusion class inheritance:
System.Object
Rhino.Runtime.CommonObject
Rhino.Geometry.GeometryBase
Rhino.Geometry.Surface
Rhino.Geometry.Extrusion
ExtrusionObject class inheritance:
System.Object
Rhino.DocObjects.ModelComponent
Rhino.DocObjects.RhinoObject
Rhino.DocObjects.ExtrusionObject
The former has an IsCylinder method, but the error message implies you are using the latter which doesn’t.
EDIT: Use ExtrusionObject.Geometry in order to get to the Extrusion object.
HTH
Jeremy
Thanks!
Don’t forget you can also cast the Extrusion to a Brep - my_extrusion.ToBrep()
- and then check the face(s) for a cylinder…
