Idle Process Curiosities
Hello Forum,
I am running Rhino 7. I have been attempting to set Idle Process(under Rhino Options) to save my document when I get up etc. I am aware that it is not supposed to run cyclically, just once after the desired elapsed time has passed, and that it will only run after a command has prompted a reset.
I have found in my case that running any command(that I have tested) doesn’t prompt the Idle Process to begin. The only thing that triggers it, which I found by accident, is minimizing the window!? I am not sure why this works or what information this grants those of you with more knowledge to troubleshoot. Perhaps a plugin with license checking is halting the idle, not sure.
Thanks for the help - Charles
hi @Charles_Sauter it should work as you describe and in a brief test here, that’s how it works.
pls run _SystemInfo in Rhino and post back the results.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 2-27-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.71
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-27-2026
Driver Version: 32.0.15.9571
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Charles\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23345.954
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.5.7955.28487
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
to test if plugins are not causing this, temporarily disable the plugins that don’t ship with rhino and see if the problem persists.
To disable the plugins, run _PluginManager, list the plugins that don’t ship with Rhino, uncheck them and restart Rhino.
