Hi all,
Rhino 7 is taking a very long time to load, and it appears to be related to the coompatibility test. I know the solution is to update the slow plugins’ build pipelines to compile against Rhino 7, but I’m not sure which plugins to look at.
Is there a way to figure out which plugins took which amount of time to run the compatibility test? Are they listed in the same order as the Rhino plugins that do not ship with Rhino
from the SystemInfo
command?
thanks!
