Hi everyone, can u plz guide me that ,how can I create a custom graphic line setting in grasshopper where the perimeter lines of trees are thicker, and the interior lines are thinner? I want the thicker lines to be around the entire perimeter of the trees, while the interior lines should be thinner. (or even for this step i need to seperate the outer lines with inners and it’d help me a lot.)
(Btw,I need to do that in revit using Dynamo,but I need first to find the logic here in gh and then try it in revit for my representation sheets)
line weight i’ll work with it in revit. but I do use both method tnx @Joseph_Oster . I used to use convex hull in dynamo,it didn’t work . I’ll try use rhino inside . Problem solved so far.. Thank u both
