I just discovered the joyful fact that there’s a conflict in alt-usage when drawing a _handlecurve and using osnaps, because if you hold alt to insert a kink you turn osnaps off. That makes it very difficult to do a handle curve based on reference geometry.
I was wondering if you can record a screen capture showing how you’re trying to use Osnaps while also inserting a kink? I was trying to figure it out here to offer some possible workflows but I don’t think I’m getting the intended workflow.
Sorry, I see the issue now…
I’m thinking to draw another curve for the kink and Join after. The result seems the same as using HandleCurve with kinks.
Hi Brian - try drawing a HandleCurve with Alt to force a kink at the placed point while also snapping to a point using osnaps - it does not work… You need to override Alt as far as I can see, with a particular one-shot osnap.
Yep, and this is annoying, not being able to turn off the alt-toggle for o-snap usage. I’d like to just re-assign the hotkey for the toggle to something other than alt. Or assign a different modifier key for kink insertion. Either way.
I wanted to create a smooth sweep curve in 3d that was based on a series of already modeled parts that didn’t have the transitions I wanted. I agree that it was not ideal, I ended up punting on that method and surfacing in a different manner entirely.
