Icons on the right-side disappeared. The command " ToolbarReset" works only for the main toolbar on the left side but not for the right one/
Hello - if you mean the panels on the right (by default) these are not ‘toolbars’ but are opened via the Panels menu - or just running the Layer
command should pop those open as well - any luck?
Yes, but I want it to pop up by default
Hello - once opened and docked on the right, close and reopen Rhino - are these panels still there?
Yes, they are. I just want it to look like after installation. How to put it one into another so that there will be one tab with 4 inserts?
Hello - you can right-click on any of the panel tabs and choose which panels to show - I think the defaults are
Layer
Properties
Display
Help
Finally ! Thank you for the assistance
also pressing the F3 key will work
quick way. thank
