So the image explains it all. I’m very sorry if it has been mentioned in the forum before, but I couldn’t find anything.
Some of the icons use white lines for additional information. Because the submenu also uses a white background, only the black part of the icons is visible.
This is true for
- the lower part of the “lines” menu
- the “extend curve” menu
Even though it doesn’t make rhino unusable at all and it adds a “discovering effect” to the menu, I think it should be changed for better readability.
A solution could be to use the same grey as the “active tool palettes” as a background for the dropdown menus.
