Icon issues
I’m having an issue when using icons in the wip.
When clicking on an icon which has a sub-menu ‘underneath’ it (see pic below), it always pops the menu up and I have to click again on the icon that is displayed as the default icon in order to get the command to activate.
In v7 a single click would activate the command on the icon and then a longer ‘held’ click would bring the menu up. I find this to be a much quicker way of working, where as the wip behaviour just seems to waste my precious time!
Is there a setting I’m missing to change this behaviour to match v7 instead?
Hi Rob,
So you are saying that a normal click (so not on the triangle) opens the popup, am I reading that correctly? I don’t see that behavior, here it seems to work identical to V7
Thanks for the reply Gijs, yes, you understand correctly!
That’s odd then… maybe I should do a complete uninstall/reinstall of the wip?
I’ll give that a try and report back.
no reinstall, try to do a repair first
Doh! Too late, did the reinstall and nothing changed.
Then did the repair, but still nothing changed!
I must be stuck in my own personal hell… :scream:
that’s odd, pls send your _Systeminfo
Hi @mcvltd,
Has this setting been changed?
Try tweaking it.
HTH
Jeremy
Ah ha! Thanks @jeremy5
For some reason my wip setting was 20! I changed it to 400 and it’s now exactly as expected. :+1:
Thanks to both of you for the help!
