I would like to now how the fillet edge (of a solid) component works
unhandled
#1
In the latest version of Grasshopper (at least), there is a component for filleting edges of a solid. I haven’t been able to get it to work, so I was hoping one of you could show an explain its function.
2018.05.15_mcneel_forum_re.gh (3.2 KB)
GH Fillets, Rounds, Edge Blends, Radius, and Chamfer
#2
2018.05.15_mcneel_forum_reV1.gh (5.2 KB)
(David Rutten) #3
The trick is you have to provide a list of integers that identify specific edges. You can generate these integers either by hand (as @HS_Kim did) or you can use one of the many edge-index-components that sit next to the fillet edge component to create these integers. The various components all provide different way to ‘select’ certain edges.
#4
#5
Per usual, you have gone above and beyond my expectations. I was struggling finding the correct format for plugging in the edges.
Thank you!
#6
These components are found only in Rhino 6 ?
“Convex edges” and “Fillet edge”
#7
Yes, they are…
