I want to move the same part to the same coordinate value
I have to manually move the new parts to the same coordinate values as the parts already assembled by eye. It is very time consuming.
Is it possible to copy the coordinate values and instantly move them to the exact same position?
Hi Tatsuya Hmmm. you’ll want to orient/rotate as well as move the parts… correct? - I’d think Orient3Pt is your friend here - snap to three points on the object and three correcponding points on the target object.
Thanks for the reply.
I also want to do orientation and rotation.
I think Orient3Pt would work well.
I will try that.
Thank you so much!
you could also use OrientCameraToSrf with option Set Construction and then RemapCPlane
Thank you so much!
