I want to keep the line SDL component and adjust the size of the line connected to the end point separately
20201031225331
Hello, I connected the two points using the line SDL component. After that, I changed the size to change the pattern, and the whole scale changed. However, to maintain the shape of the circle, I would like to keep the line connected to the line SDL component, but only reduce the size of the line made at the point of the end point component.
What should I do?
1031.3dm (31.6 KB)
1031.gh (38.3 KB)
The top-left-most curve parameter in your file references a Rhino curve. You’ll either need to internalise that data or also post the 3dm file which contains that curve.
Thank you. I uploaded an additional Rhino dm file.
You can connect a wire from Line SDL to the group used to make the polar array:
Yes. I mean, I want to keep the lines made of polar arrays. In that state, I want to adjust the size of the line created at the end point while adjusting the slider.
The problem now is that all of the connected lines are shrinking. But I only want to reduce the size of the line connected to the end point.
